WIFI IIC-800 wifi not showing
Recently I got a batch of inkbird IIC-800. However one set when I powered up the flashing wifi icon is not showing up. I tried to reset the unit but still not showing. Even if I pressed the left botton for 2 sec, the flashing icon still did not appear. Hence, I was unable to connect this to my wifi. Pls advise.
Please press and hold the left button of IIC-800-WIFI for 3-5 seconds, and then wait for 5-8 seconds. Will its WIFI indicator light up?
If not, could you provide a problem video, and order information to email support@inkbird.com?
I am unable to pair the device with the flashing wifi
If the WIFI indicator of IIC-800-WIFI flashes quickly, but cannot connect to WIFI.
Please make sure that the Bluetooth and location permissions of the mobile phone are turned on, the router transmits 2.4GHz wifi.
Router settings:
Wireless protocol: 802.11 b/g/n, but cannot be set to 11n only;
Security mode: WPA/WPA2
Authentication type: AES
Enable DHCP service
When pairing, please place IIC-800-WIFI next to the router as much as possible, which can avoid unstable signal and cause connection failure.
For more details, please refer to this post:
