I have just purchased a smoker controller, ISC-007BW.
It has connected correctly and I have added it as a device I to the Inkbird Pro app. However I am seeing the wrong interface in the app.
I am not seeing the correct interface/information as per the manual. (I have a photo of the manual showing what I mean but cannot attach a second photo.)
Instead, I am seeing lots of Chinese characters and information that I cannot make sense of, as per the screenshot attached.
This means I can’t see or set the temperature via the app, or in fact perform any app functions for the device.
May I know the phone model?
Is the Inkbird pro app the latest version? This problem may occur if it is an older version.
In addition, the ISC-007BW supports the INKBIRD app, which is an upgrade from the Inkbird pro app.
If the Inkbird pro app still has problems, maybe you could try the INKBIRD app?
It was the latest version. However I have now tried the INKBIRD app – this works in that I can now control the device and see the temperature, however I now have a new issue – the app won’t let me see the data chart and data history, it just says “No data”. I would be grateful if you could advise.
May I know if you are using WIFI or Bluetooth connection?
Please keep the ISC-007BW connected to the app.
Because it takes time to record data.
If you wait for a while, will it have the chart data?
I contacted the engineers and they replied that they would fix this problem as soon as possible. They expect to update the app within the next few days.
Just to confirm, are you using the INKBIRD app, not the INKBIRD pro app?
If it is INKBIRD app, please copy the device ID via ‘more’ on the upper right corner and provide it to me.
