IPT-2CH is a controller that can control 2 heating pads separately to maintain different temperature ranges, and the target temperature of its 2 outputs can be set independently.
If you encounter a situation where the IPT-2CH output (heating pad) will not turn on, please check:
- The power of the heating pad is in the range of 250W.
- The heating pad will work when plugged directly into a power outlet, and it does not require a button to turn on.
- The setting of IPT-2CH is correct, its screen/app will show that the corresponding output is heating.
If you still have problems, please feel free to email support@inkbird.com.
