Firstly, please make sure:
- the heater power used is within the 250W limit. If the limit is exceeded, it may damage the IPT-2CH. Due to the low power of the heater, it may take time to heat up, please be patient. The temperature of the environment also affects the heating speed of the heater.
- The heater does not need to be switched on manually when it is powered on, it can heat up to the target temperature. It can be tested by connecting it directly to a power outlet.
- the IPT-2CH is set up correctly.
The output test will be divided into the following cases:
the IPT-2CH and app show work1 is heating, but work1 does not work.
Please test:
a) Plug the heater into the IPT-2CH work1 socket.
b) Disconnect the IPT-2CH from the power supply, press and hold the ‘SET’ button on the left side, then release the ‘SET’ button when the power is on.
c) It will go into test mode, please press the ‘up’ button within three seconds, the work1 output will be switched on.
Please check if the heater of work1 is working. -
the IPT-2CH and app show work2 is heating, but work2 does not work.
Please test:
a) Plug the heater into the IPT-2CH work2 socket.
c) It will go into test mode, please press the ‘down’ button within three seconds, the work2 output will be switched on.
Please check if the heater of work2 is working. -
IPT-2CH and app show work1 heating off, but work1 still works.
Please test:
a) Plug the heater into the work1 socket of the IPT-2CH.
c) It will enter the test mode. At this time, the work1 and work2 outputs are not working.
IPT-2CH and app show work2 heating off, but work2 still works.
Please test:
a) Plug the heater into the work2 socket of the IPT-2CH.
If there is any problems, please contact after-sales service via email support@inkbird.com
