The product is great and works well except after if reaches target temperature and the temp drops below the target I have to go to settings screen and back again for it to start heating again. This means I have to baby sit the controller if I want it to stay at or near the target temp.
Is it possible to provide the current temperature reading, and the setting of IPTC-2CH?
I just reread the instructions and I misunderstood how to work the low range and high range. Essentially I expected it to work off of the high range only but now i understand once it gets to the high range it cools down until it reaches the low range and then turns on again.
I tested this out and it works perfectly. I adjusted the temps to surround the temp I had it mind so it will go back and forth between low and high and that is just fine.
Thank you for the reply.
