I have an inkbird ITC 308 wifi. And accidentally overloaded it. More than 10A. Everything seems to be working normally but I am not getting any voltage on either socket. What breaks when overloaded and what can I replace to get it working again?
Sorry, the maximum current supported by the ITC-308-WIFI socket is 10A. If it exceeds the limit, its relay may be damaged and cause output failure. If it is damaged, it is difficult to repair
You blew the rely contacts.
In order to carry a load even close to 10 amps you need to use the InkBird 308 to drive a power relay.
The output of the InkBird goes to the field wires of an auxiliary relay rated at 20 to 30 amps
Use that relay to control the heavy load.
I used a similar layout in my garage where the inkbird 308 drives a 110v auxiliary controller relay and
the auxiliary relay then controls the 220v line to feed a 5000w electrical heater. My auxiliary relay is a double pole single throw controller rated at 40 amps and my electrical heater draws about 28 amps … SAFETY MARGIN.
You might be able to open your 308 and replace the relay but for time, effort, safety and the cost of a replacement miniature relay … It Just Ain’t Worth It.
Buy a new 308 and use it as a driver.
The relay suggested will handle up to 40 amp and up to 330vac.
You may Google … AD-PR40-2C-120A
Or look at this site : https://www.automationdirect.com/adc/shopping/catalog/relays_-z-_timers/electro-mechanical_relays/ad-pr40-2c-120a?gad_source=1&gad_campaignid=18010732041&gclid=EAIaIQobChMIgLjU3dzdjQMVPGdHAR1bHxfbEAQYBSABEgKSL_D_BwE
Using this concept you may power most come equipment.
Thanks, I ordered new relays on eBay
