ITC-308-WIFI - AMP Rating of 10 AMPs
Hi There,
I am reaching out in regard to the ITC-308-WIFI.
I am looking to use it with an air-conditioned used to cool my server home lab. I’ve been looking for a smart plug to be able to turn on my air-conditioner when the temperature rises as I use the ambient air to cool my servers when possible.
My air conditioner operates at 11 AMPs sustained. I’ve tried a variety of smart plugs and I can’t find anything that are rated higher then 10 amps or can operate slightly above the rating without tripping a fuse inside. Does the smart controller trip if a device were to run sustained at 11 AMPs?
Please understand that the maximum current supported by the ITC-308-WIFI is 10 amps. If you use an 11 amps device it will damage the ITC-308-WIFI, please do not use them together.
Thanks for the info. No worries I won’t use it then and will return it.
Can you refer me to an alternative product that will suit my purposes?
It’s really annoying the air conditioner is supposed to be rated for a max of 10 amps per the documentation but it exceeds it anyways.
The hunt continues…
Hi IDReplogle !
I’m currently facing the same problem with the ITC 308… I plugged my chest freezer into the ITC 308, but unfortunately the amperage isn’t strong enough, so my freezer does not work.
Did you find any other device that supports more than 10 amps ?
Thanks in advance !
Hi Tania, any improvements on the ITC-308-WIFI regarding the 10 amps cap ?
I can’t plug my chest freezer cause it’s 12amps and I need a temp control on it !
Thanks in advance.
Sorry, the current version of ITC-308-WIFI is still 10 amps :cry:.
Ya’ll keep in mind that the 10 amp limit is only on the controller. It can be used as a primary switch that controls a circuit with a higher amp rating. Example: If the ITC-308 was used to power a 24v transformer, the transformer can operate a set of contacts that feeds power to the freezer, AC, Heater, Etc… I have built a few of these that I usually control with a remote. I just replace the receiver with the ITC-308 for cooling/heating. This also allows me to put a longer cord to reach the equipment I am controlling. Let me know if I can help you.
