My IIC-400 stops in manual mode after about 10 seconds
Hi everyone,
I recently bought an Inkbird IIC-400 and successfully connected it to my Wi-Fi network.
My setup:
  • 2 irrigation zones
  • 4 wires
  • Black wires connected to C
  • Red wire connected to Zone 1 and Zone 2
  • No rain sensor installed
Since I don’t use a rain sensor, I keep the yellow jumper wire between S and 24. The connections are secure and not loose.
In the app, I also disabled the “Main Switch Rain Sensor” option.
Problem:
When I start the zone manually from the app, the sprinkler starts correctly but stops after around 10 seconds.
After it stops:
  • all LEDs blink simultaneously
  • all 4 zone LEDs are green
  • the rain sensor LED is red
The firmware/app is up to date.
I already tried:
  • enabling/disabling the main valve switch
  • enabling/disabling rain sensor settings
  • running scheduled irrigation programs instead of manual mode
  • tried with only one zone, and 2 wires
Nothing worked so far.
Has anyone experienced this issue or found a solution?
Thanks!
The connected wire
If the water valve stops working in manual mode, please check if its specifications are within the 24VAC, 1A range. Its voltage cannot be 24VDC/9V, or the inrush current will exceed 1A. This is the most direct cause of the zone failing to turn on properly.
You were right, I need to use 24VAC valves.
I changed them, and it works now.
