Cant seem to find a unit that just heats at a certain temp and cools at a certain temperature. Instead of having a set tempurature.
Ryan
Ryan
May I know your country?
Do you mean, for example, want to use a heater to maintain 40-50 degrees and a cooler to maintain 60-70 degrees?
Canada. Yep just like that. Like a Home thermostat would work.
Ryan
Maybe you can see if the ITC-608T+2 temperature probe version can meet your needs?
The total equipment power it can withstand is 120V, 15A, 1800W.
It has work1 and work2 outputs. In dual temperature mode, its work1 and work2 outputs can be set separately.
Instruction Sheet: ITC-608T User Manual (in English) 20201214.pdf - Google Drive
Product Link: https://www.amazon.ca/dp/B07MH7GQ4N/ref=emc_b_5_i?th=1
