I have a small mechanical ball valve I want to control by temp. I was looking at the ITC 1000, 110 v The valve is very low draw. Does the ITC look like a good option? Also does it come with the temp. probe or do I need that also? If I’m using 110 v input is the output also 110v ? Also can I set it to operate at a 2 or 3 degree shift in temp. Thanks
ITC-1000 will come with a probe.
Its target temperature setting range is -50°F~210°F / -50°C-99°C.
The output port of ITC-1000 also needs to be connected to power source.
Please refer to:
Thanks now I understand the voltage in is the same as the voltage out. I am only interested in the heat side. Can the temperature drop that activates the switch be regulated or is it preset? If preset what is it?
Also is there controller that does the same thing ( I don’t need cooling only heat) but would send me an alert wifi to my phone should the temperature exceed the limit? Would the 306 T wifi alert me through an app on my phone as to a temperature issue? Thanks
The heating working mode of ITC-1000 is:
TS is the target temperature, and DS is the temperature difference value.
When the temperature reaches/ below TS-DS, it will turn on the heating output, and turn off at TS.
For example, if you want to maintain the temperature range 58°F ~60°F. Please set TS=60, DS=2.
When the temperature reaches/ below 58°F (TS-DS), it will turn on the heater, turn off at 60°F.
ITC-1000 menu settings:
ITC-1000 cannot set a custom alarm range.
ITC-306T-WIFI only has heating function, and can set a custom alarm range. If ITC-306T-WIFI is connected to the INKBIRD app, when it triggers an alarm, the app will push a notification.
ITC-306T-WIFI menu settings:
Thank you. my goal is to be able see if the temperature was to exceed the TS for some reason. Using my home wi fi and my android phone would I be able to see that when I’m not at home?
I received my ITC 1000 could youexplain the purpose of the orange sliding plastic tabs on the sides? thanks
If you mean ITC-306T-WIFI, when it is connected to the 2.4GHz wifi at home, the phone can view the data remotely.
The orange sliding plastic piece of ITC-1000 is used for fixing during installation.
please elaborate on how to use the orange pieces Thanks
For example, ITC-1000 can be installed in a box. Since the panel size of ITC-1000 is larger than the body, ITC-1000 can pass through the front of the box, and the orange slide can be pushed in from the back of the body to fix the panel on the box.
Please refer to:
I lost the screw that holds the back plate on can you give me it’s specifics so I can get a new one? Thanks
Thanks for the quick reply. That’s the location of the screw I lost. But it seems a pwa screw is a self tapping screw. I do not beleive that was what was there
