I’m trying to set up a vent system for a cold room and looking for a controller that will turn the fan on when the outside temperature is below a setpoint (say 5 C) and the inside temperature is above a setpoint (say 5 C). Will this one do the job? Inkbird Temperature Controller with Dual Temp Probe ITC-608T 15A Digital Thermostat 12 Periods Timer
Sorry, the ITC-608T does not compare the temperature difference between the two probes. It works separately based on temperature readings and the settings.
Hi Tania
Do you have another controller that would work? Note, it doesn’t need to compare readings just simple logic if probe 1 under target and probe 2 over target, turn power on.
Doug
Sorry
, there are currently no products that meet this requirement.
