Hi we have a tortoise and got a tubular heater linked to the ITC308 WiFi to try and maintain a set temperature overnight. We want 13 degC and have set on the thermostat and also in the app but the temp drops below and the heater doesn’t seem to kick in. Says it’s in cooling mode … we want heating! Really can’t seem to work out what to do … how do you set this so it kicks in with heat when needed? Any help appreciated
Before using the ITC-308-WIFI, please quickly check the following:
Does the heater automatically turn on and heat to the target temperature after being powered on? Please understand that the actual heating temperature is determined by the heater itself.
Does the heater have a built-in temperature controller? Please understand that this may affect the control of the ITC-308-WIFI.
The heater’s power is within the range of 100-240V, 10A.
Regarding the ITC-308-WIFI, please also check if its settings are correct.
Please refer to this post:
