ITC-308 WiFi face plate peeling off
I’ve been using an ITC-308 WiFi in our greenhouse to both monitor the temperature and run a fan when needed. The face plate is peeling off. Other than trying to re-glue it back on, is there a recommended solution?
Please make sure that the ITC-308-WIFI body is not exposed to direct sunlight or is in a high temperature environment.
If its face plate peels off, it can be glued back on.
If the panel is damaged, please provide order information and photos of the problem to email support@inkbird.com within the warranty period.
