ITC-306T-WIFI Trend
  1. It would be helpful if the report would show if the heat is on or off possibly using a different colour or line thickness on the graph to distinguish the state.
  2. Would it be possible to have the temperature range of the report be representative of the differential in the settings instead of the current +/- 22C? It would be more helpful if the range was more granular.
I will send it as a suggestion to the engineer, thank you.
Is there a way to expand the graph in the app mapping the heat trend.
I set my two probes to 18 and 18.5 so it heats when the temp drops below 18 but the line is almost straight so I cannot determine the time taken for the temp to drop or heat back up.
Be great if I could expand the graph so I could see the trend line in more detail.
