How do I calibrate the thermometer and hygrometer so I can check to see if the Inkbird is accurate?, and how do I save these calibrated values when I enter the values into the 0.00 slot. Thanks.
The INKBIRD sensor is factory calibrated. It can also be compared with other accurate thermometers/ hygrometers. If there are deviations, it can be calibrated via the Engbird app.
For example, if the sensor is 2 degrees lower than the actual reading, please enter 2 in the temperature calibration settings, then please click on the blank position on the current page and it will automatically save the settings.
The same applies to humidity calibration settings.
Thanks. I think I have this worked out.
How do I set a negative temperature correction value? There seems to be no way to enter the minus sign. If I try a very high value, it tell me the permitted range is -50 to +50, but I can’t find out how to enter a negative value.
Please click on the input box and enter the negative calibration value manually. It is possible to enter the minus sign. When finished, please click the blank position near the input box and it will save the setting.
If it still has problem, please provide the sensor model, phone model and a video of the problem to support@inkbird.com.
These will help us to determine the problem.
I have 2 different IBS-TH5 devices. They both have VERY DIFFERENT readings for humidity. Like 7.5% difference. Do they need to be calibrated?
Maybe you could do a salt test and calibrate them? Even if the models are different, it works the same way:
If the readings are off, it can be adjusted with the calibration settings.
I’m assuming that when you say the devices have different readings, that they beside each other. I have 2 about a foot apart in a large humidor with different readings on the different shelves. Considered I tried the salt method which showed them both off by different amounts. Something about this didn’t seem right so I purchased a Boveda calibration kit and both were accurate.
