Can you adjust the temperature after the decimal point on the ITC-308 Wi-Fi?
I want to set my target temperature to 77.5F on the ITC-308, but it appears to adjust in whole numbers only (i.e. 77, 78, 79, etc.). Is there a way to change this in the settings or am I stuck with whole numbers?
If the temperature unit is Fahrenheit, it can only be set to an integer.
If the temperature unit is Celsius, it can be set to one digit after the decimal point.
Thank you for responding so quickly. Maybe Inkbird could consider adding that feature for fahrenheit in a future update.
You can set the temperature offset fractionally so your reading will be 0.5 degrees high or low (depending on the sign of your offset).
