Re Purpose the 308 WiFi cooling output to an independant output
Is there a way to reconfigure the 308 WiFi Cooling output to be a 2nd heating output?
The use of the cooling output is of no use to me and requires me to leave it unused needing multiple controllers. If I could configure it to be heater output 1 and heater output 2 it would be the ideal product and I would buy another 2 units.
The simgle probe is OK as the logic could be
If temp between time a and time b is less than x
turn on heater 1
else turn off
if temp between time c and time d is less than y
turn on heater 2
else turn off
Sorry, cooling output cannot be changed to heating output. Its programming is fixed.
ITC-308-WIFI working principle reference:
