A: 1. Confirm that the temperature reaches the heating off value, the work indicator is off, but the heating output is not turned off.
- Check the power of the heating equipment (voltage and watt), too much power may lead to equipment damage;
Step 1:
Do you mean when the temperature reached heating target value, the work indicator of ITC-306A is off, but the heating outlets still on?
Could you please let me know the voltage and watt of the heater?
Step 2:
If the power of the heating device is within range and the built-in thermostat is OK, try the following steps:
Input Power: 100 ~240VAC, 50Hz/60Hz
Temperature Control Output: Max. 10A, 100V ~240V AC
Unplug the controller, plug heating devices.
Hold the SET button (don’ t loosen it till power-up)
Connect the power supply to power it on, then release the Set button (within 2 seconds, otherwise, it will enter normal mode)
Press the down button, Please do not press the up button. Are the heaters turned on? (within 2 seconds, otherwise, it will enter normal mode)
This is a test mode, it can check if there is a problem with the heating outlets.
