Q: How to set the temperature and humidity of ITC-608T (function of IHC-230)?
A: For example, want to control 30-40 degrees for heater, 50%-55% for humidifier.
Please set:
HC=H
TS=40
DS=10
HD=H
HS=55
DS=5
Others are default.
When temperature reaches 30(TS-DS), it will turn on the heater, turn off at 40(TS) degrees.
When humidity reaches 50%(HS-DS), it will turn on the humidifier, turn off at 55%(HS).
