My IHC-200 maxes out on the humidity when it hits 89.3% rh and it never reports anything higher (when its mid 90s). Its solid on 89.3% rh and doesnt vary. The room humidity is 42%.
Could you please clean the probe and cable, then use a hairdryer to dry the entire unit for a while, then test the probe in the air, can it read correctly?
Thanks for your reply. I actually was in the process of doing that when you replied and it seemed to work. But it worked too well as the unit started recording 103% humidity.
It is in a very humid environment but I doubt it is over 99% rh.
24 hrs ago i put the sensor in a sealed bag with a vessel containing a salt and water slurry to try and calibrate it to 75%. Its holding steady at 75% after calibration so I will move the sensor back to its original sensing location to see what I get.
Thanks again for your reply. It seems to be the key to my original problem
Sensors have been calibrated and returned to their high humidity locations and are reading in the mid to high 90’s as expected.
Looks like ive resolved both issues. Thanks
