I have ITC-608T and pluged in my heater for work one and I want to use a fan to come on in work two but the fan to be controlled by the humidity sensor in the greenhouse is this possible to work in that way.
If ITC-608T is plugged with temperature and humidity probes, its work1 is used for temperature control, and work2 is used for humidity control. It can be plugged into the work2 if you want to use the fan as a dehumidifier.
thankyou, It’s programmed and working great.
