Not heating up water. Even added hot water to make it go faster. It keeps dropping
Please check if the water capacity is too large.
The maximum limit of ISV-100W water capacity is 15L. If the limit is exceeded, it may cause slow heating. If it is within the range, please set the target temperature to a different value for testing.
If it still fails to heat up, please provide a video to show this problem and contact support@inkbird.com via email.
Looked this question up on reddit. I unplugged it and plugged it back in. And it worked fine
