I can’t get this to change. Probe plugged in not plugged in it reads 300 degrees constantly. I’ve tried a reset and it prompts me to upgrade firmware from v1.0.0 to v1.0.6 it appears to complete then the temp reading drops to 0 then immediately goes back
To 300. I reset again and again it says update firmware! It’s like Groundhog Day! Food probes temps work perfectly. How can I fix this?
Sorry to hear that it brings you inconvenience.
Regarding ISC-027BW firmware upgrade, please make sure that the ISC-027BW is connected to the INKBIRD app, and then follow the steps below to complete the firmware update:
- Please disconnect the power of ISC-027BW.
- Press and hold the button of ISC-027BW.
- While holding the button, reconnect the power supply.
- Release the button when the status LED alternates between red and green.
- Please make sure the WIFI indicator of ISC-027BW is blue and solid, which means it is connected to INKBIRD app.
- Open the INKBIRD app, select ISC-027BW.
- Please follow the on-screen firmware upgrade prompt to complete the process.
If you have any doubts during this process, please feel free to let me know.
