I find it strange that the older ISC-00BW is able to update the APP at same time as giving local controls and a local display. INT-14BW by contrast is EITHER local OR wifi and cannot offer both.
would be good if it could, such as seeing both ambient and target temps on wheel press even when connected via wifi. Currently once on wifi its locked to only display current internal temp.
Changing target and ability to see target/ambient/internal all on the local device should really be standard.
Sorry, different products work differently. INT-14-BW local mode and WIFI mode cannot be used at the same time.
