So I have an inkbird that has been working for a year, but periodically it will give me some issues.
I use it for a freezer that i stop the temp at 36 degrees Fahrenheit. The inkbird broadens the range since the settings on the freezer won’t allow it to be set higher than 5 degrees.
It has been working great for most of the year but now it’s not stopping the freezer when the pre-set temp of 36 is met. It keeps freezing, which means all content inside freezes
When the freezer is above temp the green cooling light is on, but when it drops below the pre-set temp the heating light is red. So it recognizes it is past it’s setting but still doesn’t turn off the freezer.
Please advise
