INKBIRD IIC-600-WIFI - Malfunction Notification?
Is there an Alarm/Notification for when there is any kind of malfunction that prevents an irrigation cycle from starting or completing? Although the history showed that is ran the proper cycles, something bit through one of the valve box wires, so the water did not turn on and I almost lost some of the plants.
If not, is it something that could be added to via software upgrade?
Thank you!
The IIC-600-WIFI turns its outputs on or off based on its settings; it cannot detect whether a water valve is connected to an output, nor can it determine if a water valve itself is faulty. Therefore, this functionality may not be achievable.
