IIC-600-WIFI notification and history
Can IIC-600-WIFI send notification and alarm when finished irrigation for automatic and manual ? I only have notification and alarm when started.
Also, I noticed that some times, irrigation is not added to history.
Sorry, currently there is no notification when irrigation is finished.
May I know your phone model? Maybe I can get an engineer to test the history function.
My phone model Huawei P30 Lite MAR-LX1A.
As attachment
1) case where History was OK for all programmed irrigation
2) case where history is ok only for some programmed irrigation
3) Alarm message that are ok for all same date when problem is there
Thanks,
Thank you for the information, the engineer will test it.
In addition, could you let me know your country?
If possible, please provide the device ID of the IIC-600-WIFI.
The device ID can be copied via IIC-600-WIFI → ‘…’ in the top right corner.
Here is the ID bf2dab4471b6b896f6ajkd, I’m in Morocco.
I solved the problem by disable than enable all zone.
