IIC800 memory transfer to replacement unit
Hi. I am wondering if there’s a way IIC800 memory can transfer to replacement unit. My unit developed a fault and the new unit is a new install. I’d still like to keep all the irrigation data if possible and transfer it to the new one.
Sorry it doesn’t have this feature.
A way that I have found to quickly set up a new unit is to ensure that the Zones are connected in your desired watering sequence 1 to 6 or 1-8 depending on the model you have.
Then using the multi regional function set all zones to same start time and water durations that are common to the majority of zones. Then go back and edit Zones with identifying names and other changes unique to that zone.
