I wonder if I can use my current existing AC24V power cable through “AC24 Port (+ and -)” instead of using the Inkbird power supply through “power in” port in IIC 800 WIFI?
I try to avoid calling electrician to pull the cable.
It is ok, but please note that the power cable voltage is within the 24VAC, 1A range.
Thanks a lot Tania. I tried and it works smoothly ![]()
