IIC-600-WIFI output current capacity
I wish to connect two valves to one port. 0.4 amps inrush with 0.2 amps holding current each. Can one port operate with this load? If not, then is it possible to have two zones come on for exactly the same date and time.
Also how many zones can operate concurrently. I am concerned re drive capacity as nil mentioned in manual. I note the supplied power supply is rated at 24vac 1000ma.
Thanks in anticipation.
The ports of the IIC-600-WIFI cannot be opened at the same time.
The current that a port can take depends on the supply current, which is 1A.
If the total current of the 2 water valves is less than 1A, they can be connected to the same port.
