Is it possible to hardwire the 24V/1A power supply to the unit, rather then using the provided plug?
If yes, where exactly should the power + and - be connected? Can you show a diagram?
I have a 24V1A power supply wired to the place of installation.
If you don’t want to use a power adapter, please connect the 24VAC, 1A power supply to AC24 Port (+ and -). Please note that it does not support DC power.
Thank you!
Sure, it should be AC power.
If I don’t use a rain sensor and I wire directly the power as you wrote, I should leave the jumper wire between S and -24, correct?
And just to be sure: dc power + wire goes to VAC+ port, and - wire to 24- port?
Please note that it is 24VAC, 1A power, not DC power.
If you don’t use a rain sensor, the jumper wire between S and -24 doesn’t need to be removed.
Please connect the power 24VAC+ to 24VAC+ port, power 24VAC- to 24VAC - port.
