IHC 200 time programming
Hello. I want to run my dehumidifier at night at the off-peak rate. Does the IHC 200 Wifi support time programming? If not, if I program the power supply of IHC 200 via a separate device, does the servo start automatically when the power is turned on ? Thanks
The IHC-200-WIFI does not have a time function. the IHC-200-WIFI will save the preset settings, it will automatically switch on when the power is turned on.
Thank you Tania, works for me !
