- “Is IBS-P01R (FCC ID 2AYZD-IBSP01R) compatible with IBS-M2 gateway?”
Thank you
Thank you
There are currently two versions of the IBS-M2, please check the IBS-M2 version, or consult the seller.
When the IBS-M2 is powered on, if it displays ‘80’, it is the second-generation version and does not support connection to the IBS-P01R. If it does not display ‘80’, it is the first-generation version and supports connection to the IBS-P01R.
