Iam-T1 calibration problem after battery change
I was using this device for past 3 months. Everything was going fine.
Then the battery went low. I changed the battery. And after I changed it. The calibration went out of range. It was showing 198 as normal.
Then I pressed auto calibiration, then factory reset, then auto and so on. So that it reaches right level. But everytime I clicked factory reset. The value went down and down and down. And now its placed outside in open area. The reading is 114. The more times I press factory calibration button, further down it goes. Now I have kept it in the open with auto calibiration on. 27th October, 2026 9:30 AM IST.
At 10:00 am I said 169.
Now at 9:00pm it says. 111. Which is not right
It should show somewhere near 460 as it used to.
w 169.
Since some batteries have a relatively low voltage, this can affect the device’s operation. It is recommended to use non-rechargeable alkaline batteries for the IAM-T1; perhaps you could check the battery specifications or try using batteries from a different brand to see if that resolves the issue?
Thank you so much. I changed the batteries and inserted duracell alkaline batteries. And its working normal again.
