How to force the ITC-308 to turn-off cooling without returning to the set value?
TS is 72, HD is 2, CD is 13. So, cooling comes on at 85. I’d like cooling to stop at 80. Is there a way?
Please understand that ITC-308 can only set a target temperature TS.
It cannot do this unless the TS is changed to 80 and CD is changed to 5.
The way ITC-308 works is:
When the temperature reaches/ lower than TS (temperature setting value) - HD (heating difference value), it will turn on the heater, turn off at TS.
When the temperature reaches/ higher than TS + CD (cooling difference value), it will turn on the cooler, turn off at TS.
