Using both probes with the ITC-608T, (humidity and temperature probes), is possible to wire a fan in a chicken coop to regulate temperature and humidity?
If this controller doesn’t support it, what other controller would you recommend to achieve my goal of controlling a single device (fan) which would reduce humidity or temperature when it exceeds a certain threshold especially during the cold season (winter).
