Hello
I have a tank of water and I wish to to connect it to my flash water heater . The water heater is 240v. My goal is for the controller to turn on heater until the water reaches around 75+ degrees. Do you have a product for me. Thank hiu
Perhaps you could see if the ITC-306T meets your needs? It can on/off control the heater to maintain a temperature range.
Manual:
Do you have one that works with 240 volts?
Thank You
Hovik Akopyan
The ITC-306T can work with 240V supply voltage, but please note that the total power of the heaters cannot exceed 240V, 10A, 2400W.
