May I know if the app you are using is INKBIRD or Inkbird pro?
If you wait about 3 hours, then re-enter the app, will it still show this message?
Using the inkbird pro app. The morning after now and indeed the msg is gone and I can try again.
Problem is rust I can’t turn of my regular network (both 2.4 and 5 ghz). My guest network only used 2.4 ghz but so far haven’t been able to connect to that.
If you want to change the WIFI, please remove the original ISC-007BW from the app then reconnect it. Please place the ISC-007BW next to the 2.4GHz wifi router, this can prevent the problem caused by weak WIFI signal/ interference by other devices.
Please check that the new WIFI is set up correctly. Please refer to:
