Temperature Calibrating the IBBQ-4T on the inkbird app
How can I calibrate the inkbird IBBQ-4T probes on the inkbird app. The temperature on the probe I’ve used is out by at least 10 degrees Celsius
The IBBQ-4T can be calibrated to a range of ±12°F/ ±7°C. The 10C deviation exceeds the calibration range setting.
Please put the probe and the probe’s cable (excluding the probe’s plug) in an oven at 150C (302 F) for 30 minutes and then test with boiling water (please hang the probe so that it does not touch the container). Does it work?
Please note that the cable of the probe (silver wire) is not waterproof. Please do not immerse the cable in the water when washing the temperature probe.
Please do not put the probe/the probe’s cable in the fire or in a place where the temperature is higher than 250C/482F. Otherwise, the probe and cable will be damaged.
Hi - I’m having the same problem. 2 of my probes are inaccurate by 60-65 degrees F
Any tips? The device is only a couple months old & I haven’t used it that much.
May I know if you have tested what I mentioned before, will it still have a big deviation?
If yes, please provide the order information and the problem picture to the email support@inkbird.com for after-sales service.
Since forum posts are public, this may involve private information, please do not reply here.
Hi - Yes, it seems to work after putting it in the oven, and then boiling water. I’ll test again next time I’m smoking or BBQing something. Thanks again.
calibrated probe using the ice water and when using it now it just sits at 32 degrees. When a probe I did not calibrate says 54 degrees Fahrenheit
I’m new to this system and I have ITC-308 manual. I’m in the uk and want to set this up for my greenhouse for heating. I don’t need it for cooling. I want to set a constant temperature at 10 degrees Celsius. Can anyone help me with the settings please. Thank you.
