Hi there!
In the process of buying a sous vide and I can’t seem to figure out the difference between the ISV-W100 and the ISV-W101, would love to get some guidance.
Thanks!
Hi there!
Thanks!
ISV-100W and ISV-101W are two different models. Please choose according to your needs.
In addition to appearance differences:
ISV-100W uses an LCD screen. The temperature setting range is 25ºC~99ºC (77°F~210°F). When the temperature reaches the target temperature, it will issue a prompt, but the heating function needs to be turned off manually .
ISV-101W uses a TFT screen. The temperature setting range is 0-90°C/32-194°F. After the temperature reaches the target temperature, it will automatically turn off the heating function.
