Wish the app for your Pool Thermometer would capture our pool temperature and record it to the app allowing me to read the temperature when I am away from home. It only connects and reads from one room in our house even though our pool is very close to our house.
Please understand that IBS-P01B is a Bluetooth connection, it will be affected by the Bluetooth distance. If you want to achieve remote viewing, please use the IBS-M1 gateway with it.
The IBS-P01B can be connected to the IBS-M1 gateway through Bluetooth, and the IBS-M1 gateway can be connected to the phone app through the Internet-enabled 2.4GHz wifi transmitted by the router. After the connection is successful, you can read the temperature on your phone when you are away from home.
I do have the IBS-P01B and the IBS-M2. How can I connect the Pool-Thermometer to the gateway?
Please connect the IBS-M2 to the INKBIRD app via 2.4GHz wifi first.
After the connection is successful, please add the IBS-P01B manually via the INKBIRD app - IBS-M2 - ‘+’ in the top right corner.
hello,
when i click the “+” in the inkbird app the only suggested controller is the IBS-TH-1. It is not possible to add the IBS-P01B.
Please add IBS-TH-1.
After successful addition, please check if its reading is the same as IBS-P01B?
Because IBS-TH-1 is the reference name of the searched sensor, its name may be different from the sensor model.
o.k. yes, is working well now. Thank you!
