Where can I obtain the PC Tool software?
Is there a way to reset the Air Quality Detector - the unit will no longer respond to WiFi.
Thank you!
Thank you!
Day 2: Regarding my question about resetting the Air Quality Detector; I left the unit unplugged overnight. It reset itself once the internal battery was completely drained. It is now operating correctly. Note that it is not enough to merely unplug the unit from the USB port and shut it off. The battery must be drained over several hours.
Are you referring to IAQM-128W?
If yes, PC Tool please refer to:
https://drive.google.com/drive/folders/18q-oxxqcsE3IfPVuLa3cZOrHe2nWQNBZ?usp=sharing
