I have 2qty ivc-001w which i am using for a mvhr unit, is it possible to set the fan speeds to 1 for example until it sees the humidity go up then increase the speed until the humidity has been cleared.
IVC-001W operates according to the preset fan speed. If the fan speed is set to 1, when it is turned on, it will work according to the fan speed 1, it will not change speed.
thank you Tania, I think Ink Bird are missing an important detail with this option and a simple software update. so I will have to build my own controller
