Hello,
Maybe you can use ITC-308-WIFI slow flash mode to connect?
It is a one-to-one connection method, and the connection effect will be more stable.
Please refer to troubleshooting:
If it still doesn’t work, maybe you could try the hotspot connection test mentioned in the post? That could help further check what the problem is.
