ITC-308 alarm keeps going off
I bought an ITC-308 to operate a fan in my greenhouse. I set it up last year, no problem. This year, the alarm goes off all the time and drives my dogs crazy! Is there a way to shut it off completely? Or a way to program it so it very rarely goes off? I have another WIFI unit that lets me monitor the temperature and alerts me on my phone so I really don’t need an alarm on my Inkbird…
Please check if the reading of ITC-308 is correct?
Does it display the alarm code when the alarm goes off? For example AL/ or AH?
Hi, mine is doing this as well now. It was working just fine and then the alarm started going off with the AH flashing on the display. If I press a button the noise stops for a while, but eventually comes back on. I’ve unplugged it for a while, but that didn’t help. Alarm started as soon as I plugged it back in. The unit is in my greenhouse and temperatures are between 0-10 C right now, so nothing unusual, and AH was at default. I adjusted the AH level a little, but that did nothing.
Please check if the current temperature reading is correct?
If correct, please check if the AH setting is correct?
The AH and AL means, when the temperature reaches/ above AH, or reaches/ below AL, it will alarm.
Please note that if the current temperature reaches or exceeds the AH value, it will trigger an alarm.
If you don’t need the AH alarm, please increase the AH value.
For example, if the current reading is 10 degrees, please set AH=20
