Hello
I just set up the IPT-2CH on a 2.4Ghz network at home. I would like the scheduling to be remote (e.g. if I am away at work, and my app is not connected to the same network, I would like the schedule to push the temperature command regardless). But right now, I’m experiencing two inconveniences:
- The temperature controller will only send commands when the app on my iPhone is connected to the same 2.4GHz Wi-Fi. I was unable to get scheduling to work when connected to a different Wi-Fi band.
- Scheduling triggers only when the specified time is reached. For example, if I set something to schedule at 3PM, if I connect to the Wi-Fi at 3:01PM, the command will not send.
So in summary, is there a way for temperature scheduling to work remotely, even when the phone app is not connected to the same Wi-Fi as the IPT-2CH? And additionally, is there more robust scheduling capabilities on the InkBird app (e.g. set 70F whenever time is 3:00PM - 7:00PM)?
Thank you!
