I experience on and off Inkbird smart controller Line Error. What causes this?
Please restart your device.
If it still shows ‘time error’, please provide order information and problem photos to support@inkbird.com for after-sales service.
Anche io da oggi stesso problema
Ciao,
Se riavvii il dispositivo e il problema persiste, fornisci le informazioni sull’ordine e le foto del problema all’e-mail support@inkbird.com per il servizio post-vendita.
If you restart the device and it still has the problem, please provide order information and a problem picture to email support@inkbird.com for after-sales service.
After restarted, 1 min later the problem again appear. How to resolve this issue?
IIC-800/ IIC-800-WIFI has a 2-year warranty.
Please send an email and provide order information & problem picture to support@inkbird.com within the warranty period for after-sales service.
I have had the same exact problem just started doing it out of the blue. Getting a replacement under warranty from reseller. He said that error means it has an internal fault.
I am still facing issues with LINE ERROR…usually after 6 months from installation.
Is there a solution to this problem?
Perhaps you could reset the IIC-800-WIFI.
To reset the IIC-800-WIFI, please unplug the power, press and hold the ‘Power’ button, then plug it back in and release the ‘Power’ button until the device powers on.
Will it work?
If it does not work, please provide your order information, a picture of the problem, and a link to this post to email support@inkbird.com for after-sales service.
My replacement has the same issue again! I can’t believe even the replacement is faulty. It’s lasted about 6 months too ![]()
[quote=“Okjames, post:8, topic:166128, full:true”]
I have seen a technical suggest solution in responses to post with similar Error Problems. @Role posted the suggestion which I am going to test. I consider this a very positive finding and has the possibility to reinstate stable operation.
