Inkbird IIC-800-WIFI - Zone
Hi. I’m planning to buy the Inkbird IIC-800-WIFI however, from searching this forum I found out that the 8 zones can’t run at the same time.
Can someone confirm if this has been fixed (software) or if a new product is/will be released?
Sorry, as this feature is a hardware design, it cannot be adjusted via the app.
Currently INKBIRD does not have a product that meets this requirement.
The Zones operate sequentially based on the nominated start time. If the start time for each zone is set to the same time it will start in order of 1- 8 Zones sequentially. A zone can be set to start up to 6 times in a 24 hour period.
So unlike the restrictions on other watering system controllers, each Zone can be set to operate relative to the garden or lawn needs.
Do you actually need all Zones to operate at the same time ? If so the operate off 1 solenoid only!
Hope this helps!
