My IIC-800-WIFI is currently operating fine on my WIFI network. But this WIFI network will change soon (new SSID and new password), how can I setup the new WIFI, without loosing my current settings on the device?
Thanks for your help ![]()
Cheers
If you want to change the WIFI information, please understand that the device needs to be reconnected.
Please select INKBIRD app - IIC-800-WIFI - ‘…’ in the upper right corner - More - Remove device - Disconnect.
Please be careful not to select ‘Disconnect and wipe data’.
Then please connect IIC-800-WIFI to the new 2.4GHz wifi.
Hello Tania, thanks for your help, everything went well ![]()
