When I measure the output voltage at terminals “M” and “C,” I already get 2.7 VAC when the system is off; when a zone is turned on, it’s 30 V. This means that my connected relay is always energized, even though it hasn’t actually engaged yet. Is this normal?
Perhaps you could connect a 24VAC, 1A solenoid valve for testing (please ensure the voltage is correct; it cannot be 24VDC/9V/110V/220V, etc.)? If using a master valve, please ensure the total current of the master valve + solenoid valve does not exceed 1A. Considering the possibility of inrush current, it’s better to limit it to within 0.8A.
Because using a multimeter may produce false voltage readings, it is recommended to rely on the solenoid valve’s actual performance.
Also, please ensure the IIC-400-WIFI wiring is correct.
